Teamcenter FSC is not starting .
Builder
Builder
Hello Team,
am trying to update the base version of Teamcenter 10 with TC10.1.5 but, i started FSC after patch update its failing am not getting how to get issue resolved.
attached is the screenshot of services
Sameer Kulkarni.
6 REPLIES 6
Re: Teamcenter FSC is not starting .
Siemens Creator
Sameer,
Check the environment variable FMS_HOME is correct.
If that is correct check even in the tc_profilesvars.bat if the FMS_HOME is correctly handled.
/Ramin
Siemens Legend Siemens Legend
Siemens Legend
what does your TC_ROOT\fsc\FSC_<hostname>_<userid>stdout.log say after your start attempt?
maybe it can't access some volume paths?!?
If you replaced tc_preferences.xml with new one from data.zip check TC preference fms_bootstrup_url - this preferense value must correspond to your servet_host:port
Siemens Legend
@Ramin: why need checking FMS_HOME? it's the Teamcenter FSC Service running on the server - not the FMS-Client-Cache at the client...
@alex_c: Teamcenter FSC Service does not login to Teamcenter to evaluate preferences - so I don't see a need to check the FMS_Bootstrap_URL preference...
@sam11: could you be so kind and provide us the TC_ROOT\fsc\FSC_<hostname>_<userid>stdout.log of your FSC Service so we can determine what's the root cause for the not starting issue?
Siemens Creator
@MarkusK Oh, my misstake it should be FSC_HOME.
