Teamcenter Login failure
Teamcenter 10.1 login failed
com.teamcenter error
Re: Teamcenter Login failure
You'll probably want to give some more info for the issue. That we someone can give you more custom feedback.
My first step would be to look at the log file. See what errors specifically you get.
Be more specific about the error as said by @JK_13 and refer syslog file for errors
Is it com.teamcenter.soa.error ?
If the error is as mentioned above
1. Check services (teamcenter related) in server with your administrator start if not started.
2. Login into data base and start instance
3. Properly map network ans check for server name and IP in the host file
4. Clear temp(%temp%) & RAC (in user Folder)
5. Restart the system and login
Best Regards,
Jeethan Rohan
thanks for the solution, it is working now
