Teamcenter Product Configurator
Do any one implemented Product Configurator? Can someone help me on how to enable this in RAC? According to documentation, it is specified that no special activity is needed to enable it. But when I log in, i dont find it in the list of modules.
4 REPLIES 4
Re: Teamcenter Product Configurator
What is the Teamcenter Version you are using?
Yashodhan
Product configurator needs to be installed from TEM.
I would double check on the license front as well for product configurator.
while I was told that I can use product configurator without 4gd license, I had difficulty in accessing some product configurator features in structure manager.
let know how it goes.
Best Regards
Harish
Could you please let me know what Teamcenter version you have? Steps may vary based on it.
Yashodhan
were you able to fix the issue ? I have the same problem where can find the documentation for the same
{Raghavendra Prasad},
Production: {TC 11.4.1}
