Teamcenter Upload/Import Help
I'm sorry if this topic has been covered many times already, but i've searched around and spoke with GM data specialists and i still can't get a step by step answer...
At my old job, i uploaded full die designs to the Ford TC and bumped rev levels, no problem.
This job, we deal a lot with GM and i've uploaded data for reference in TC by opening TC, opening NX from within TC, File, Import and selecting a single component or assembly (i'm still learning how to correctly upload assembly this way...)
My current delema is that i can't figure out how to upload a product assembly into GM TC.
Ownership was transfered to me, i revised the previous PN under the EWO's "Solution Items". It automatically selected rev 002, so i kept selecting Next, until it was greyed out, so i clicked on Finish.
A small automated checklist window popped up, then it dissapeared and the screen looked the same...
So i searched for the specific part number that i was changing and it shows 002 unfrozen. How do i upload an assembly to that folder? I've literally spent all day asking GM specialists and reading through a million PDF's, but i can't seem to figure this very simple process out... It can't be that tough, right? I tried named references and uploading over the previous PRT, but when i downloaded the assembly, only that single PRT had changed, the rest of the assembly is old data still from the 001 rev...
Re: Teamcenter Upload/Import Help
File > Import Assembly into Teamcenter, should be used to import parts/assemblies into the teamcenter.
You have revised only a part from an assembly or root assembly part?
Is it 'Soution Items' folder of an ECR/ECN?
Could you please mention some more details/steps so that it would be easy to help you on this.
