Teamcenter Visualization Mockup 11 vs. 10 performance issues
Would anyone be able to point me in the right direction of why VisMockup 11 is performing worse than version 10?
At thye moment, loading a model takes twice as long in 11 as it does in 10, and overall performance after loading the model is also worse.
Is anyone familiar with causes of this issue? Admin rights, read/write, 32/64 bit, etc...?
Thanks in advance,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
Re: Teamcenter Visualization Mockup 11 vs. 10 performance issues
These types of issues (software not performing) are normally solved by GTAC. They will develop a patch after investigating the cause. Report with full debug logs.
Evaluating: AW 3.4
