Teamcenter Visualization - green square
Hi everyone,
Few days ago I found that in an assembly opened with Teamcenter Visualization Base 10.1, some files appeared in the pathfinder with a green square in front.
Does somebody knows why?
Please find attached an image about the issue.
Thank you in advanced!
Re: Teamcenter Visualization - green square
Vis is telling you it cannot find the Geometric Representation for that component.
Verify that the appropriate JT dataset(s) have been created under the Item Revision.
Thank you very much for your answer. You've solved my problem.
