Teamcenter /change ownership
We have about  100 folders in teamcenter and each folder contain about 100 assemblies  and some folders contain sub assemblies and parts , also it does include just parts.  we need to change the ownership from supplier ID S to Supplier ID W . Is there any way to list all the parts so we can use the command edit - change the ownership ?
Thank You ,this is hot request
{Raeed Kena}, {CAD Software Developer}, {your company name here}
Production: {NX 11 & Teamcenter}
Development: {Visual Basic} Testing: {NX 11 & CATIA}
Re: Teamcenter /change ownership
You can try listing using Teamcenter 'General...' query with owner set to Supplier 'S'.
Select the root node in search result panel and click on 'Details' view.
In the 'Details' view, set filter condition to further refine objects based on type, owner etc.
filter_search_results.jpgFilter Search
Harish
How can I search for all parts ( parts ,assemblies and sub assemblies)  that have owned by specific user ?
Thank You
Thank You
Hi raeedkena,
You can go to "Simple Search" query and search for parts with filter as "Owning User" with value <specific user>
