Teamcenter create_project utility
The create_project utility gives the user the ability to create ‘Project’ objects through the command line and add members to the projects. I would like to know if there is a utitlity to just update existing projects(not create) with user information, for example to add or remove users from an existing project.
Re: Teamcenter create_project utility
That utility doesn't exist yet. Projects are still hard to manage.
Evaluating: AW 3.4
