Teamcenter disable web application
Is it possible to disable the Teamcenter web application (thin client) while still allowing the thick client access to the application?
Re: Teamcenter disable web application
If you install 2tier then you won't need the web application but you will be restricted by latency to remain close to the DB server (and TC_DATA). 4tier, as the name implies, requires the web application. You might be able to tinker with the application files to disable the thin client (like removing the login page). Give GTAC a call.
Best,
/Randy
Evaluating: AW 3.4
