Teamcenter login error: POM has not started
Hi everyone
I am getting this error while Teamcenter login
Error:
com.teamcenter.soa.client.SoaRunTimeException: POM has not started
I checked the DB services and all are running.
i have already stop and started these three services (OracleServiceTCDB, OracleOraDB12Home1TNSListener, OracleVssWriterTCDB) but i still have the error
I am using Teamcenter 11.3 , NX11.0.2.7, Oracle 12
21 REPLIES 21
Re: Teamcenter login error: POM has not started
Is it just one client or all clients?  If its all clients then look in the syslogs on your server.  If its just 1 client then clear caches, kill java processes, reboot, try logging in to your pc as another user etc
And, try searching the forum:
https://community.plm.automation.siemens.com/t5/Teamcenter-Users-Forum/Error-in-login-to-teamcenter/...
Richard
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
I am working on the server and I can't log in to Teamcenter on server. I checked the linked but the recommended solution didn't work. DB services are running
Is there another remote session logged in to the server?  Is it just the server you have an issue with, are the clients ok?
Richard Bennett
PLM Consultant
I have this problem on server and client. I am the only user that trying to login. No remote session loged in.
What does the syslog say?
Richard Bennett
PLM Consultant
I can't find syslogs. Where should I look for it?
Who installed Teamdenter? Have you been able to login at all? Is it a new install or an upgrade?
Richard Bennett
PLM Consultant
We have this problem scince a week ago, and we where using it about 6 month.
Of course we loged in it.
You have been using Teamcenter for 6 months and haven't been able to login for a week either on the server or your clients?
I think you need to raise a call with your reseller or Siemens.  It could be a simple fix, or it could be a problem with Oracle.  I would get this error when we had problems with the Database being full.
Syslogs are usually located in the user profile temporary folder, just type %temp% in the address bar of windows explorer.
Richard Bennett
PLM Consultant
