Re: Teamcenter login error: POM has not started
Thanks Richard
Good day, earlier in Oracle 11, the default password period was set for users and at the end of this period Teamcenter could not connect to Oracle, check that you can log in under infodba in oracle, for example using sqlplus
Got it. Thanks
Also set the password expire limit to UNLIMITED in oracle DB
User gets "POM has not started" when trying to login to TC.
Oracle service and listener were both started.
install -ayt did not return "Site is already installed"
The password for the infodba Oracle account was expired. Change settings so the password will not expire. The infodba user is locked out, password expiration was set to 90 days, and last login was longer (TC_days_non_login_timeout).
Update PPOM_USER set last_login_time=null where puser_id='infodba';
Start command shell:
set ORACLE_HOME=<your home>
set ORACLE_SID=tc
sqlplus
Enter user/pass (infodba might work…. or you may need to use the SYSTEM login)
select expiry_date from dba_users where username='INFODBA';
select profile from dba_users where username='INFODBA';
# change the password for user infodba to infodba.
alter user infodba identified by infodba;
# prevent this from happening again in 6 months.
alter profile default limit PASSWORD_LIFE_TIME unlimited;
alter profile default limit PASSWORD_GRACE_TIME unlimited;
alter profile default limit PASSWORD_LOCK_TIME unlimited;
alter profile default limit FAILED_LOGIN_ATTEMPTS unlimited;
This allowed the user to login
Evaluating: AW 3.4
Did you check that the password of DB account for Teamcenter is expired? sometimes happenens by DBA's policy.
when i am trying to start listner, its not starting please see below attachment. give the solution as soon as possible
how to check?
Try start listener via command promt
set ORACLE_HOME=
cd %ORACLE_HOME%\bin
lsnrctl start LISTENER
Dear Expert,
Thanks for quick reponse,
its not working please see below attachment
