Teamcenter preferences for Multi-Cad configuration:
Hello I am trying to perform the multicad configuration for the integration of NX. Part of the configuration need to be done in the teamcenter preferences...
According to the help of NX (see next picture) I have to set those preference as they explain in the picture...
My problem is with the ones that are underlined in the picture because they dont appear in my teamcenter preferences...so I do not know what to do ...
I saw that I can create a new preference definition but I need to know what category should I use for them ...
Any idea what to do here?
Thanks a lot
Re: Teamcenter preferences for Multi-Cad configuration:
These are JT specific preferences and be created without a category. If you are using "foreign" datasets in NX (like JT) then you may need the first pref. If you are exporting/importing JT's then the position pref may be required.
Evaluating: AW 3.4
i add this to category General
dj
