Teamcenter10_Unit Conversion
How to convert units from MM to INCH or INCH to MM in Teamcenter 10 & UG NX 10
Re: Teamcenter10_Unit Conversion
The ug_convert_part utility does not convert parts stored in the database.
Export the file out of the database and use the ug_convert_part utility to convert the unit.
Regards, Ben
