The issue for ID generation rule
The help ask us to configuration stylesheet to create ID
But in my virtual machine have a error, help has a problem?
Re: The issue for ID generation rule
Please, check that the property names correspond exactly to those you are using, they also are case sensitive.
Yes,the property is exactly correspond
Do you hava successful case? which is the release version of TC?
TKS for MCF's fans
No I do not. But as fa as I remember I went over the examples in the documentation with no problem (v 10.1). There is an example where an autogenerated ID rule is created and shown into the Rich Client.
Please, make sure your Business Object contains the property shown in the error. I'll try to find time to make a working example. If you suspect it is a bug, please, contact GTAC.
Yes,My objects and propertys are right
Thank you onece again!!
