The type org.osgi.service.event.Event cannot be resolved. It is indirectly referenced from required
I am trying to create teamcenter plugin (Create a custom Viewer view),
example from client customization programmer's guide.
i followed all instructions, but getting following error so not able to build plugin.
The type org.osgi.service.event.Event cannot be resolved. It is indirectly referenced from required .class files HelloWorldViewerFactory.java /com.mycom.customviewerview/com/mycom/customviewerview/factory line 1 Java Problem
How to fix this error?
 check attached images for reference.
Thanks !!
3 REPLIES 3
Re: The type org.osgi.service.event.Event cannot be resolved. It is indirectly referenced from requi
Try this: Double click MANIFEST.MF in project -> Go to 'Dependencies' tab -> Add the plugin 'org.osgi.service.event.Event' to "Imported Packages"
I mean add Package "'org.osgi.service.event" to "Imported Packages"
Thanks !! It worked.
