Re: Transfer Mode For Exporting all Parents For a Child
If you change the Action to "PROCESS+TRAVERSE", maybe you will be able to have the relation.
I use it with an Excel Template, so I never test it with PLMXML export.
We're you able to get the relation between parent and child? I also need the levels?
Not sure how
With a PLMXML, you have all nodes, so you can count the levels.
With an Excel Template, you have to define one line per level: {%L-0}, {%L-1}, {%L-2}, ...
Is there any way that I can input multiple Parts and get all their respective parents in the report (Similar report but need to fetch for multiple parts)?
Multi-selection before launching the transfer mode.
I had a similar requirement and I tried to combine the CRF PS BOM Structure closure rule with the one which you have provided but it does not seem to display the connection between a child and parent.. All I need is a parent child relationship in XML. Product view element  which is a PLMXML element holds all the occurrances from Parent to child. I'm not able to fetch product view and traverse the values from child to its parents via closure rule... Can you please provide some inputs on this?
Shruthi
