02-15-2018 09:40 AM
WIN SERVER 2012
Java JDK and JRE 8U151 installed.
Is there any setting to enable the Java plug-in of IE?
Solved! Go to Solution.
02-15-2018 10:11 AM
Evaluating: AW 3.4
02-15-2018 11:18 AM - edited 02-15-2018 11:21 AM
it's solved,thanks very much!
I have set the following two enviroment before:
JAVA_HOME=C:\Program Files\Java\jdk1.8.0_151
JRE64_HOME=C:\Program Files\Java\jre1.8.0_151
and follow your instruction I install x86 jre-8u161 and set JRE_HOME,add 192.168.*.* tot he Exception Site List on the Security tab in the Java Control Panel. then,it works!
