Unable to login to TC - getting an error message FSC proxy error
I'm unable to login to Teamcenter which is installed on my machine. DB Server and client is installed on same machine.
Re: Unable to login to TC - getting an error message FSC proxy error
Look for the file in the volume and if it doesn't exist then create it. You may go through this cycle a number of times (14?) with different file names (all *.bin) before you are successful. Basically, the lang files Tc needs are missing (probably from a custom bmide template deployment) and by creating empty text files with the same name then Tc is able to proceed.
E:\TC\Siemens\volume\dba_596857ba\094800_unk_ff3049k72oz3l.bin
(Tip: use your TcRAC log to copy the file path/name to prevent typos. C:\Users\<os_user>\Teamcenter\RAC\<genxml_datetime>\<username>_TcRAC_<session_datetime>.log)
Evaluating: AW 3.4
Thanks Randy for the reply. the reported file is present at mentioned location. Still I'm getting same error.
Can you attach your TC_ROOT\fsc\FSC_*.stdout?
Evaluating: AW 3.4
Please find attached file....
The FSC is reporting that it cannot find this file:
File not found 'volume 00ec5968a50f8e2cf5a3(E:\TC\Siemens\volume)dba_596857ba\0948000_unk_ff3049k72oz3l.bin
If the file does exist in the volume then it must be a permissions issue. Ensure that all the files in the volume are owned by the user running the FSC service.
Evaluating: AW 3.4
did you try to running bmide_setupknowledgebase utility and then restart server.
Sometime during wrong BMIDE deployment may lead to this issue also. otherwise as Randy said must file missing case from volume.
I tried but.. I found the Model.xml file is missing from TCdata model folder.
How can I get the model.xml file ?
Sometimes a failed deployment can result in the DB schema and files in TC_DATA becoming out of sync...
1. Set the environment variables PASSWD and TEMP_WORKING_DIR
2. Copy all of the template files into the temporary directory:
set TEMP_WORKING_DIR=C:\Temp\CompareDB
set PASSWD=infodba
copy %TC_DATA%\model\*_dependency.xml %TEMP_WORKING_DIR%
copy %TC_DATA%\model\*_template.xml %TEMP_WORKING_DIR%
copy %TC_DATA%\model\lang\*_template_*.xml %TEMP_WORKING_DIR%\lang
copy %TC_DATA%\model\master.xml %TEMP_WORKING_DIR%
3. Consolidate the template files:
%TC_ROOT%\bin\bmide_consolidator -dir=%TEMP_WORKING_DIR% -file=model_consolidated.xml -consolidate=all
4. Extract from the database:
%TC_ROOT%\bin\business_model_extractor -u=infodba -p=%PASSWD% -g=dba -outfile=model_extracted.xml -mode=all
5. Compare templates vs. database:
%TC_ROOT%\bin\bmide_comparator -compare=all -new=stage_model_extracted.xml -old=prod_model_consolidated.xml -delta=check_delta.xml -log=compare_model.log
%TC_ROOT%\bin\bmide_comparator -compare=all -old=model_extracted.xml -new=model_consolidated.xml -delta=check_delta.xml -log=compare_model.log
6. Rename the extract.xml file to model.xml and the lang\extract_lang.xml file to lang\model_lang.xml. Replace your TC_DATA\model\model.xml and \lang\model_lang.xml files with the new ones just created. Run the following in a TC cmd prompt:
%TC_ROOT%\bin\manage_model_files -u=infodba -p=%PASSWD% -g=dba -option=upload
Evaluating: AW 3.4
Just set TC_CLIENT_CACHE=1 as env variable or in your portal.bat and it will solve your issue
