Versions of ItemRevisions
How can I adjust the number of versions of ItemRevisions that can be saved.
Thanks in advance!
Re: Versions of ItemRevisions
Is the preference TCDefaultKeepLimit what you are looking for?
xtof
Ist exactly what I'm searching for! Thanks alot!
Do you know how to clear the versions whenever needed?
Select IR and then run Edit -> Purge
See also TCDefaultKeepLimitByType.
Evaluating: AW 3.4
