Viewer shows different info
NX9 and TC 10.1.2
If I select different parts in TC, the viewer tab looks different.  Some parts show what I would expect in the JT Preview tab, and others show a small image and some text info.  See attached images.
The only difference I can think of, is the one that displays the image and text is an assembly in NX, and the other is not.  I don't recall this behavior in the past.  We recently updated to Tc 10.1.2 from 10.1.1, and NX9 from NX8.5.
Thoughts? or is this the way it's supposed to be?
-Dave
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Viewer shows different info
For an assembly you will see the preview image.  For a piece part the viewer will render the .jt file.
For the assembly to view the 3d, you have to switch over to Structure Manager or one of the other Apps (Multi Structure Manager etc.).
Thanks.
Biggest issue was operator error.  I had accidentally removed the "summary" tab, so what I was expecting with my far left tab had changed, because the tab changed.
-Dave
