Vismockup automation help
I am trying to customise some of the tasks in vismockup going through the samples files in installation folder.
Need some help in understanding a method in VisDisp3DView Object. In this object there is a method called find.
Find (INPUT_TYPE InputType, FIND_NODE_TYPE NodeType, String strPropName, COMPARE_OP CompareOp, VARIANT PropValue1, VARIANT PropValue2, VARIANT OutNodeList)
PropValue1 - Value of the property named in strPropName to compare against or start of range to compare against.
PropValue2 - End of range to compare against.
I use the above command like below.
gView.Find(0, 1, "Name", 2, "*", "", AssemblyNodelist)
My question is if I want to find list of assembly names containing any of this string ['1000', '1001', '1002']. Is there any easy way to do this other than using for .. next.
Thanks in advance
