WORKFLOW HANDLERS
Hi experts,
I strucked with a problem while using rule handler "check-responsible-party".
i placed this hander on perform action of start task. you can find it in below attachments.
and i am getting error.go through attachments.
waiting for your suggestions..
Thank you.
12 REPLIES 12
Re: WORKFLOW HANDLERS
The handler appears to be working flawlessly. Your group in DBA yet the handler expects CAR. The business rule has not been met. What's the problem?
Evaluating: AW 3.4
I initiated the workflow by using specified user:1234,Group:car.
but still it is showing "Business rules for handler 'check-responsible-party' on action 'Add Attachment' in task 'plmrh1' are not met."
The handler cannot be placed on the Perform of the Root task (plmrh1). Can move it to the Perform of "New Task 1"?
Evaluating: AW 3.4
sir, i tried it by placing it on newtask.now what is the problem is any user can initiate the workflow.
i want only user:1234,Group:car should initiate workflow.
If your requirement is controlling who can initiate the workflow then you might want to look into Process Template Filter and/or apply a Named ACL.
Evaluating: AW 3.4
if its not possible by using rule hander check-responsible-party ,
then for what purpose this handler is used.
I want it to done by only using this handler.
I thaught that this handler checks for the user & group, which we specify during aasigning this handler to newtask.
It does. But you cannot place it on the root task (see image). You can always write your own handler.
Evaluating: AW 3.4
exactly right i didnt placed it on root task. i placed it on newtask1 .but the problem is , any user can initiate the workflow. i want only user:1234,Group:car can initiate.I dnt want other users to initiate workflow.
The rule handler check-responsible-party should stop  other (not specified)users from initiating workflow.but it is not hapening.
