Re: WORKFLOW HANDLERS
Try using EPM-check-action-perfomer-role instead. This handler can be placed on the Start action of the root task.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
yeah. for EPM-check-action-perfomer-role it is working correctly.
But i have to use check responsible party only.
can you just once check it.
Siemens Genius Siemens Genius
Siemens Genius
I guess for your requirement,
EPM-check-action-performer-role is the correct handler.
The "EPM-check-responsible-party" is used only to set the responsible party for the sign-offs. Guess this goes with a DO task. This is my understanding.
