What is the best method to create drawings in Teamcenter managed environment
Hi guys,
What is the typical approach for creating drawings in Teamcenter?
Can I have opinions?
Create them in the UGMASTER?
Create the drawing in Master model concept?
As a Non-Master Part file?
Or else?
Cem
Re: What is the best method to create drawings in Teamcenter managed environment
Check out Scott Pigman's article on PLMDojo.com:
http://plmdojo.com/datamodel/store-drawings-teamcenter/#.VbqKF1VOmyo
He does a good job explaining pros and cons of each method.
Larry Carpenter, P.E.
