When changing a computer are TC11 Customer Defaults and such stored to a server ?
Hello
When changing a computer are TC11 Customer Defaults and such stored to a external server ?
Or stored to PC's own HDD and I must use export \ import on customer defaults every time I change computer ?
Re: When changing a computer are TC11 Customer Defaults and such stored to a server ?
As far as I know, users parameters should be stored in the database, but rich client settings, view settings, perspective settings, column settings are saved locally
C:\Users\user_name\Teamcenter
Clarification please. Customer Defaults is a term used for NX. Are you asking about Tc or NX?
Evaluating: AW 3.4
