When changing the loading Rule the Structure disappear in Catia
the customer has an assembly which can be opened in Catia using the Loading Rule: Latest Working.
However if this Loading Rule is changed, the 3D Structure in Catia cannot be seen.
Any ideas what can be done there?
TC 9.1.2.4
Catia 5.21
Thanks in Advance!
Re: When changing the loading Rule the Structure disappear in Catia
What do you see in Structure Manager for the revisions if you change to the same revision rule there?  Do you also get an empty structure?
Richard Bennett
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Hello Mr. Bennett,
thanks for your Reply. Well in the Structure Management I see the changed structure with full components. I tried to do a comparison between the both Revision Rules: Latest Working and Other custom Rule and I could see the changes in the Report also. I changed the custom Loading Rule to some other Rule and it didn't help. The 3D structure in Catia is visible for 1 second and then it disappears.
I havent got Catia so cant test...  Have you any other custom revision rules, and if so do they work?
It may be a bug?  What about editing one of the out of the out of the box rules to look like your custom rule rather than creating a new one just to test?
Richard Bennett
Richard Bennett
PLM Consultant
Other Loading Rules: no changes... Independent of the Loading Rule (Custom or Standard), only Latest Working Shows the 3D Model.
I just tried the Viewer inside of the Structure Manager and it showed me the 3D model with all the Loading Rules.
I just tried to edit the latest Working Rule and it didn't help, Still cannot see anything in Catia...
There are a number of PRs raised against earlier versions of Teamcenter and Catia regarding revision rules. Have you searched GTAC?
I searched "TcIC revision rule"
Richard Bennett
Richard Bennett
PLM Consultant
@ProspectPLMthank you for your help sir, it was a subassembly which was doing Problems. It had 2 Revisions, and the custom Revision Rule was choosing the defect Revision! Thanks again for your Reply and help :)
