Where can I find Provided Rich client customizations?
I'm following Teamcenter Customization Guide, I must use a zip file which contains samples of customization.
it's writen that this Zip found in TC installation directory but I didn't find it (teamcenter11).
Did you know where I can download it or import it???
3 REPLIES 3
Re: Where can I find Provided Rich client customizations?
It is in the Samples directory but you need to install it through TEM first. Otherwise you will not have the TC_ROOT\samples directory. Siemens Docs are unavailable right now so I cannot post a link.
Evaluating: AW 3.4
@RandyEllsworth
are there any steps to install it through TEM ??
The Siemens docs are available again so here's the link:
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:id911232
Evaluating: AW 3.4
