Workflow completion
I'm trying to close the workflow, if  particular status has been released in  TC 11.2.3
What are the functions i need to use  it here ? I'm new user for teamcenter.
Please help,
Re: Workflow completion
Can you please elaborate a bit more on the workflow design?
Harish
Actually I 'm trying to close the schedule by updating, eg.: work percent complete column -100% their corresponding workflow has to be closed or completed automaticaly by ITK function.My workflow template has start-> do task-> finish.
Please Help.
You may want to try 'epm trigger action' ITK function (with epm_complete as the 'action') to complete the workflow.
You can use 'epm set decision 2' ITK if you are using review task (instead of do task).
Harish
