Workflow - loosing objects at hand over to a sub process (EPM-create-sub-process)
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Hallo all,
just wanted to ask generally, if somebody else made the sporadic experience with the behaviour that some objects are not getting hand over from the main workflow to the sub workflow target or reference folder? Let say in > 95% its working.
If yes, what was the solution to fix the problem
Thank you and best regards
Walter
Betreff: Workflow - loosing objects at hand over to a sub process (EPM-create-sub-process)
My experience is that it is alway working fine. For further help please provide more information of you configuration, workflow, system version or/and screenshots.
Michael
Teamcenter UA | NX CAD
