Workflow not showing end status
Workflow ended normally but the status is not changing. By the solution center there was a solution: "deep refresh".
Anyone knows how this is done?
The status is not the normal flag, its a new defined icon.
Thx in advance
Re: Workflow not showing end status
maybe you can try for "refresh window" by selecting those objects and check, but not sure for "deep refresh"
"Deep Refresh" was from Teamcenter Engineering. It doesn't exist in Teamcenter Unified. Closest functionality is "Refresh Window".
Evaluating: AW 3.4
