XML style sheet
Builder
Builder
Expert all,
I have to add command like check out in XML sheet just like copy,save as,revise. but it needed jar file...how should I findout jar file(commandID)..?
8 REPLIES 8
Re: XML style sheet
Good afternoon, add the following section to your XML sheet:
            <section titleKey="tc_xrt_actions" commandLayout="vertical">
                <command actionKey="copyAction" commandId="com.teamcenter.rac.copy"/>
                <command actionKey="reviseAction" commandId="com.teamcenter.rac.revise"/>
                <command actionKey="saveAsAction" commandId="org.eclipse.ui.file.saveAs"/>
            </section>
Re: XML style sheet
Builder
Builder
Thanks ArthurRM,
but I haven't see your solution ..
will you please send it once again sothat I can open it...
Re: XML style sheet
Builder
Builder
Dear aurthurRM,
I need command id for "check out" .
If possible tell us how to find out it from config file? Becoz there are lot of files present here...so I couldn't find it ..
Re: XML style sheet
So you see the message? See below:
</section>
Why do you need the "check out" button? It is already present by default in the Summary and Viewer tab at the bottom of the window.
Re: XML style sheet
Siemens Genius Siemens Genius
Siemens Genius
The below i put an old list of what you want, As-Is no guarantee what it is 100% applicability for current version.
Команда меню
CommandID
Objects ...
com.teamcenter.rac.exportObjects
To Default ODS ...
com.teamcenter.rac.publishToDefaultOdsDotDotDot
Pack All
com.teamcenter.rac.packAll
Work Context...
com.teamcenter.rac.newWorkContext
Compare 2D Images
com.teamcenter.rac.compare2D
BOMView Revision...
com.teamcenter.rac.newBVR
Show Unconfigured Variants
com.teamcenter.rac.showUnconfiguredItems
User Setting...
com.teamcenter.rac.userSetting
Assign
com.teamcenter.rac.applyAssnList
Internal...
com.teamcenter.rac.internalTraceRpt
firstBrowseAction
com.teamcenter.rac.firstBrowse
Latest
com.teamcenter.rac.latest
Summary Reports
com.teamcenter.rac.summaryReport
Select Unused
com.teamcenter.rac.SelectUnderUsed
Non-Revisable...
com.teamcenter.rac.newGDELink
Operation...
com.teamcenter.rac.newMEOperation
Toggle Precise/Imprecise
com.teamcenter.rac.togglePrecise
Revision Effectivity...
com.teamcenter.rac.revisionEffectivity
previousBrowseAction
com.teamcenter.rac.previousBrowse
Assign Work Context...
com.teamcenter.rac.assignWorkContext
Paste...
com.teamcenter.rac.pasteAs
Edit Activity Occurrences
com.teamcenter.rac.editResource
Change Ownership...
com.teamcenter.rac.changeOwnership
Assign...
Configure...
com.teamcenter.rac.configureVariant
Address List...
com.teamcenter.rac.addressList
Verify Part Structure
com.teamcenter.rac.verifyPartStructure
From Briefcase...
com.teamcenter.rac.importFromOfflinePackage
From All ODS Sites
com.teamcenter.rac.unpublishFromPublishedToSites
Stand-In
com.teamcenter.rac.standin
Occurrence Effectivity...
com.teamcenter.rac.occEffect
Check...
com.teamcenter.rac.AcctabilityCheck
Select Occurrence Type Filters...
com.teamcenter.rac.occurrenceFilter
Check Index Status...
com.teamcenter.rac.checkIndexStatus
Up
com.teamcenter.rac.moveUpAMRuleTree
Audit
com.teamcenter.rac.auditFile
Generate Portfolio ...
com.teamcenter.rac.generatePortfolio
nextBrowseAction
com.teamcenter.rac.nextBrowse
Re-Sequence Process...
com.teamcenter.rac.reSequenceProcess
Variant Rule
com.teamcenter.rac.varRule
Only Configure Root
com.teamcenter.rac.onlyConfigureRoot
Save Configuration
com.teamcenter.rac.saveConfig
Count Modules...
com.teamcenter.rac.countModules
Remote Checkout ...
com.teamcenter.rac.sendRemoteCheckout
Check-In...
Access...
com.teamcenter.rac.access
To ODS Publication List ...
com.teamcenter.rac.publishToPublicationList
Schedule
com.teamcenter.rac.newSchedule
From Specific ODS Site(s) ...
com.teamcenter.rac.unpublishFromSpecificSites
Search...
com.teamcenter.rac.searchVI
Notes...
com.teamcenter.rac.notes
To Remote Site Via Global Services...
com.teamcenter.rac.exportRemoteGms
Component...
com.teamcenter.rac.multisiteSyncComponent
Remove
com.teamcenter.rac.removeFromProject
Register Item Id
com.teamcenter.rac.registerItemId
Item...
com.teamcenter.rac.newItem
Modify Current...
com.teamcenter.rac.modifyRevRule
Remove target from PublishLink
com.teamcenter.rac.removeTargetFromPublishLink
Top Level
com.teamcenter.rac.goTopLevel
Make Immune ...
com.teamcenter.rac.makeImmune
Assign
com.teamcenter.rac.assignToProject
Add targets to PublishLink
com.teamcenter.rac.addPublishLinkTargets
Remove In Context Override
com.teamcenter.rac.removeAbsocc
BOMView(Revision)...
com.teamcenter.rac.saveAsBOMViewRevision
Cancel Check-Out...
com.teamcenter.rac.cancelCheckOut
Print...
com.teamcenter.rac.printAs
Remote Export ...
com.teamcenter.rac.sendRemoteExport
Process Variable...
com.teamcenter.rac.newPVariable
Design...
com.teamcenter.rac.newDesign
Part...
com.teamcenter.rac.newPart
Clear Display
com.teamcenter.rac.clearCompletenessCheckDisplay
Paste Substitute
com.teamcenter.rac.pasteSubstitute
URL...
com.teamcenter.rac.newURL
Envelope...
com.teamcenter.rac.newEnvelope
Show Part Solutions
com.teamcenter.rac.showPartSolutions
Create/Edit...
com.teamcenter.rac.createRevRule
Bottom
com.teamcenter.rac.moveBottom
Publish Data
com.teamcenter.rac.publishData
Clear Display
com.teamcenter.rac.CMEbomCompareClear
Report Designer Reports
com.teamcenter.rac.report
Intermediate Data Capture...
com.teamcenter.rac.IntermediateDataCapture
Notification List...
com.teamcenter.rac.notifyList
Replace
com.teamcenter.rac.replaceFromClipboard
Up
Objects to Excel
com.teamcenter.rac.exportToExcel
Purge
com.teamcenter.rac.purge
Workflow Process...
com.teamcenter.rac.newProcess
Expand Below...
com.teamcenter.rac.expandToLevel
Resume
com.teamcenter.rac.resume
Down a Level
com.teamcenter.rac.goDownALevel
Dataset...
com.teamcenter.rac.newDataset
Process & Change Selector
com.teamcenter.rac.ProcessAndChangeConfigurator
Check-Out History...
com.teamcenter.rac.checkOutHistory
Disconnect...
com.teamcenter.rac.disconnect
View With...
com.teamcenter.rac.viewWith
Signal...
com.teamcenter.rac.newSignal
Revisable...
com.teamcenter.rac.newPSConnection
ID...
com.teamcenter.rac.newAlternateId
Expand Below
com.teamcenter.rac.expandBelowAMRuleTree
Select Completely Used
com.teamcenter.rac.SelectUsed
Perform
com.teamcenter.rac.perform
Create/Edit...
com.teamcenter.rac.createIdDisplayRule
Show/Hide In Context Bomline
com.teamcenter.rac.contectSpecificAbsocc
Select Over-used
com.teamcenter.rac.SelectOverUsed
Promote
com.teamcenter.rac.skip
com.teamcenter.rac.endItemEffect
Find lines with same logical identity
com.teamcenter.rac.findLinesWithSameLogicalIdentity
Process...
com.teamcenter.rac.newMEProcess
Show Unconfigured Changes
com.teamcenter.rac.showUnconfiguredChanges
Refresh Window
com.teamcenter.rac.refreshWindow
Run Validations...
com.teamcenter.rac.Validate
Replace User
com.teamcenter.rac.replaceInAssnList
Folder...
com.teamcenter.rac.newFolder
Open PublishLink source structure
com.teamcenter.rac.openPublishLinkSource
Find Clipboard Items
com.teamcenter.rac.avBrowserFindClipboardItems
Current Users...
com.teamcenter.rac.listUsers
Find PublishLink targets
com.teamcenter.rac.findPublishLinkTargets
To Default ODS
Top
com.teamcenter.rac.moveTop
Organization...
com.teamcenter.rac.organization
Open
Down
com.teamcenter.rac.moveDownAMRuleTree
Change...
com.teamcenter.rac.newECM
From Default ODS ...
com.teamcenter.rac.unpublishFromDefaultOdsDotDotDot
Unregister Item Id
com.teamcenter.rac.unregisterItemId
Effectivity Mapping...
com.teamcenter.rac.notPseEffectivityMapping
Remote...
com.teamcenter.rac.exportRemotePLM
Form...
com.teamcenter.rac.newForm
Unpack
com.teamcenter.rac.unpack
Unpack All
com.teamcenter.rac.unpackAll
Remove
Create/Edit
com.teamcenter.rac.createAssnList
com.teamcenter.rac.effMap
Create PublishLink
com.teamcenter.rac.createPublishLink
Remove Immunity ...
com.teamcenter.rac.removeImmunity
Structure Context...
com.teamcenter.rac.newSC
View/Set Current...
com.teamcenter.rac.viewIdDisplayRule
Replace...
Rename
com.teamcenter.rac.rename
Copy Workflow Process
com.teamcenter.rac.copyProcess
Item Element...
Start
com.teamcenter.rac.start
Assembly...
com.teamcenter.rac.multisiteSyncAssembly
Modify Current...
com.teamcenter.rac.modifyIdDisplayRule
Expand Below
Set Date/Unit/End Item...
com.teamcenter.rac.setMiscFields
View Results...
com.teamcenter.rac.ShowResult
Baseline...
com.teamcenter.rac.Baseline
Revise...
Copy Item of Line
com.teamcenter.rac.copyItem
Find PublishLink source
com.teamcenter.rac.findPublishLinkSource
Occurrence Group...
com.teamcenter.rac.newAV
External...
com.teamcenter.rac.externalTraceRpt
Connect...
com.teamcenter.rac.connect
Show GCS Connection Points
com.teamcenter.rac.GCSMode
Collapse Below
com.teamcenter.rac.collapse
Variant Condition...
com.teamcenter.rac.varCondition
Up a Level
com.teamcenter.rac.goUpALevel
Objects...
com.teamcenter.rac.importObjects
Save Bookmark...
com.teamcenter.rac.CMEsaveBookmark
Show Unconfigured By Occurrence Effectivity
com.teamcenter.rac.showUnconfiguredOccs
Down
Manage Global Alternates
com.teamcenter.rac.manageGlobalAlternates
Check-Out...
Apply Occurrence Type Filter
com.teamcenter.rac.applyOccFilter
CAE Item...
com.teamcenter.rac.newCAEItem
Workarea...
com.teamcenter.rac.newMEWorkarea
Set Override folder...
com.teamcenter.rac.setOverride
Remove Design from Product
com.teamcenter.rac.removeFromWizard
Item(Revision)...
com.teamcenter.rac.saveAsItemRevision
Delete PublishLink for source
com.teamcenter.rac.deletePublishLinkForSource
Activity...
com.teamcenter.rac.newMEActivity
Named References...
com.teamcenter.rac.namedReferences
Task Properties...
com.teamcenter.rac.taskProperties
Open Live Excel
com.teamcenter.rac.excelLiveOpen
Suspend
com.teamcenter.rac.suspend
Pack
Store Occurrence Paths
com.teamcenter.rac.createAppearancePath
Options...
com.teamcenter.rac.preferences
Open With...
com.teamcenter.rac.openAs
View / Set Current
com.teamcenter.rac.viewSetRevRule
latestBrowseAction
com.teamcenter.rac.latestBrowse
Save as CC...
com.teamcenter.rac.CCSaveAsNew
Transfer Check-Out...
com.teamcenter.rac.transferCheckOut
Signoff Report
com.teamcenter.rac.viewHTMLReport
Import Remote...
com.teamcenter.rac.importRemote
Update Variant Item...
com.teamcenter.rac.updateVi
From Default ODS
Add/Remove View Tabs ...
com.teamcenter.rac.viewTabAddRemove
Replace Design in Product
com.teamcenter.rac.replaceComponent
Object
com.teamcenter.rac.multisiteSyncObject
Assign Resource
com.teamcenter.rac.AssignResource
Expand
View
Custom Reports
com.teamcenter.rac.customReport
Show Collaboration Panel
com.teamcenter.rac.toggleNavigator
Collaboration Context...
com.teamcenter.rac.newCC
Add...
Show Lower Structure Panel
com.teamcenter.rac.toggleCCStructures
To Briefcase...
com.teamcenter.rac.exportOfflineGms
Interface Definition...
com.teamcenter.rac.newInterfaceGDE
Unlink Variant Item...
com.teamcenter.rac.unlinkVi
Add Design to Product
com.teamcenter.rac.addComponent
Complete
com.teamcenter.rac.complete
Split Occurrence
com.teamcenter.rac.splitBOM
Insert Level
com.teamcenter.rac.insertLevel
Toggle In Context Mode
com.teamcenter.rac.modifyAbsOccToggle
Configuration Context...
com.teamcenter.rac.newConfigContext
Repair Broken Links
com.teamcenter.rac.repairBrokenLinks
Graphical BOM Compare
com.teamcenter.rac.MSEInvokeGBCButton
Import Feature Data
com.teamcenter.rac.importFeatureData
Merge Scenes
com.teamcenter.rac.MergeScenes
Show Data Panel
com.teamcenter.rac.dataPanelToggle
Unload All
com.teamcenter.rac.mfgUnloadAll
Replace Part in Product
com.teamcenter.rac.replacePart
All Lines
com.teamcenter.rac.selectBelowAll
Lowest Lines
com.teamcenter.rac.selectBelowLeaf
Show/Hide Data Panel
com.teamcenter.rac.tabToggle
Load Menus
com.teamcenter.rac.loadMenus
Subscribe to Refresh Notification...
com.teamcenter.rac.subscribeRefreshNotify
Open In NX
com.teamcenter.rac.openInNX
Open Bookmark in TcVis
com.teamcenter.rac.openInPV
Open In TcVis
com.teamcenter.rac.openInVMU
Usage Component...
com.teamcenter.rac.newUsageComponent
Current Application
com.teamcenter.rac.helpApplication
Help Library
com.teamcenter.rac.helpFramework
Manage Configuration
com.teamcenter.rac.manageConfiguration
Find and Install...
com.teamcenter.rac.findAndInstall
Assign Participants...
com.teamcenter.rac.assignparticipants
All the best, Alexey.
Re: XML style sheet
@SedoykinAlexey thank you for the useful information
Re: XML style sheet
You can generate a list for your current software version by running DumpCMSConfigInfo…
1. In a Tc command window.
2. Navigate to folder where Teamcenter.exe lives (mine is in TC_ROOT\portal).
3. Run "Teamcenter -application com.teamcenter.rac.util.DumpCMSConfigInfo"
That will create a number of csv files in the /portal directory for application name, commandId and view names. Useful for Context Command Suppression.
Re: XML style sheet
Siemens Genius
Adding of two snippets, maybe it will useful
1.
you can overwrite the command name, for example, change the name for this command:
<command actionKey="copyAction" commandId="com.teamcenter.rac.copy" text = "newNameForCopAct"/>
open com.teamcenter.rac.viewer_#####.#.0.jar/\com\teamcenter\rac\viewer\stylesheet\xmlstylesheet\xml_stylesheet_locale.properties
and add there:
newNameForCopAct= Click for copy…
after that please to launch genregxml.bat
2.
If you will want to add some command to the header of your stylesheet, you need to make:
<rendering xmlns :xsi="http://blblbblblblblblblablabalbalbab
<header>
   <command commandId="com.teamcenter.rac.newProcess" text="newProc" renderingHint="commandbutton"/>
  <image soure ="thumbnail"/>
after that, please to launch genreg.xml
