batch export from wrl to jt
We have lots of wrl files to import to JT format. And only utility is VisView Professional 8.3. Is there any batch script to convert/export wrl>JT ? if no, is it possible to use visview.exe from command line to export some list of files?
4 REPLIES 4
Re: batch export from wrl to jt
There should be a wrltojt.exe in your TcVis installation to do the conversion from command line.
For exporting, importing the data there are many options like dispatcher, workflow, plmxml, utilities,...
xtof
Here is the contents of folder. No wrltojt.exe?
I have it in Program folder...
ok. I was looking wrong place. Now I've found it. And do you know how to set export settings?
