[clear_process_stage_list] Utility
I have a workflow which I want to reset. I tried reseting it but there seems to be a problem.
Can it be because I have my Teamcenter in german?
Should I use infodba user to reset the WF? or should it be done with the owning user?
Is this Syntax wrong?
clear_process_stage_list -u=user1 -p=XXXX -g=XXXX -folder=Neue Daten
Re: [clear_process_stage_list] Utility
The user that runs the utility clear_process_stage_list must be in th dba group.
If the objects are not released have a look at clearlocks -verbose.
xtof
Make sure to quote a folder name containing spaces or simply create a new folder with no spaces in the name, like "Klarmich". This folder must reside in the Home folder of the User running the utility and that user must be a member of the DBA group (as @xtof stated).
Evaluating: AW 3.4
