defined workflow simultaneously by creating a piece or item compulsorily?
How can workflow be defined simultaneously by creating a piece or item زompulsorily?
3 REPLIES 3
Re: defined workflow simultaneously by creating a piece or item compulsorily?
Good afternoon,
when creating an Item, if you click Next several times you will reach the dialog for selecting a process template. It will be launched immediately after the creation of the Item.
Thanks for your kindly response
We don’t understand your mean about "if you click Next several times you will reach the dialog for selecting a process template".
Now we have to add new part or items first , after than we can add related workflow to part or items. we want add workflow when create part or items simultaneously.
Good afternoon, you wrote the question very briefly, maybe i have misunderstood something.
Here's how to create Workflow when creating an Item:
