fileManagementUtility.GetFileToLocation c# problem
in teamcenter10,
we are trying to download a file using FileManagementUtility.GetFileToLocation. but it seems that it does nothing, no matter what we specify as parameters
 var resp1 = fileManagementUtility.GetFileToLocation(null, null, null, null);
or
        var resp2 = fileManagementUtility.GetFileToLocation(contents1[0], "C:\\", null, null);
can you please  give us an example for a correct usage ?
Re: fileManagementUtility.GetFileToLocation c# problem
In GTAC there is a FAQ showing the download of a file using Java. Should be easy to transfer this to C#.
xtof
Hi Xtof,
Thank for your quick response. Unfortunately, we are not able to find an FAQ section on the official GTAC website ( http://www.plm.automation.siemens.com/en_us/support/gtac/ .
Can you, please, provide a direct link, or a particular solution that you have in mind?
Best regards
You need your webkey, then go to https://solutions.industrysoftware.automation.siemens.com/
Search for "Correctly use FileManagementUtility.getFileToLocation" and it should get you to the FAQ.
I have done the same in C#, but using "DownloadFilesToLocation". You can check the same in below link:
http://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Export-file-stored-in...
thanx  for your help :)
