get parent ID using Report Builder
Hi
Using Report Builder
For a given child , Pl help on how to get its immediate Parent Item ID.
I am looking for the Syntax to extract the Parent Item ID
Vamsi Krishna
7 REPLIES 7
Re: get parent ID using Report Builder
Hi Vamsi,
Try 'ps_parents' if you are dealing at item level.
Harish
Hi Harish
Thanks , If can you pl help with Full Syntax
For a given BOM Line , we want to get parent Item ID
Is there any document for xsl compilation , that also will help
Vamsi Krishna
Hi Vamsi,
I think the 'parentref' within the plmxml file (I assumed you are dealing with plmxml file) might help.
This would require multiple passes (you could use apply-template in xsl) on the plmxml file to lookup occurrenceref for each parentref.
Alternatively, you can develop a python code to parse plmxml for parentref information.
Harish
Thanks Harish
Yes , we are using plmxml , against Item revision
Tried this option parentRef , but exact Syntax is still a confusion
Vamsi Krishna
Hi
I am able to extract the info by adding "BOM Line Property" to propertyset
Using the same in report Builder
Not sure if this is the correct or there is a better method.
Yes, BOMLine Property (bl_parent) or occurrence level will help extract the information.
I think I misunderstood your question and thought it was about xsl stylesheet and that you are already extracting the parent information in plmxml.
Anyhow, glad it worked.
Harish
Hi
Yes included "bl_formatted_parent_name" in the same in xsl Style sheet , thanks
- Vamsi
