how to modify a form to generate an item
a new business object was generated (item) but this already has some options when it is created, I want to know how to eliminate those options that I do not need and how to move options that I generate
Re: how to modify a form to generate an item
You can do this in Create Input Descriptor of the object in BMIDE. If you open the business object in BMIDE, you can find this option under 'Operation Descriptor' tab.
You can use style sheet also.
