import of data in to Teamcenter enterprise 2007 from enovia 3d experience
hello everyone,
My client would like to do a mass import of data in to Teamcenter enterprise 2007 from enovia 3d experience.
any suggestions on the method which can be used for this  ?
5 REPLIES 5
Re: import of data in to Teamcenter enterprise 2007 from enovia 3d experience
Both the Bulkloader and obj_load work well for loading data to Enterprise.
Tricia Crichton | Software Architect | SEAL PLM, Inc
Thank you Dear,
could you please let me know where is the document describing about Bulkloader and obj_load work  in GTAC ?
Siemens Genius Siemens Genius
Siemens Genius
Hi Mushtaque
  We have a lot of experience with Migrations (130+) as well as Teamcenter and Enovia.  In this case, migrating to Teamcenter Entrerprise is a rather odd choice since most customers are looking to move to Unified.  We suggest understanding why not move Enterprise and Enovia to a new Unified environment.  This would probably save time, money and complexity to just get it done.
As with any migration, the tools are the easy part. It's the process and the data issues that cause problems.  We have a repeatable process and proven tools along with the system expertise to help with these type of projects.
Let me know if we can help.  You have an interesting challenge ahead.
- Peter Heath - PLM Business Development Manager
ITI - Siemens Development and Solution Partner
Do you get enough support on Teamcenter Enterprise 2007. A wise idea would be, migrating it to TCUA.
The command-line help is what we usually used, just obj_load -h or bldrora -h
The GTAC documentation link includes Enterprise Documentation:
https://support.industrysoftware.automation.siemens.com/docs/tc_ent/
Go to the Administrator's manual, Appendixes, commandline utilities:
But the other responders have a good point - Enterprise is no longer supported.
