java: How to set a Property on a BOMLine in TeamCenter?
I am currently logging into TeamCenter via stanadalone code.  I can get  a BOMWindow and the BOMLines.
From a BomLine I call:
Property propertyObject = bomLine.getPropertyObject("FOO");
if (propertyObject instanceof PropertyStringImpl) {
      PropertyStringImpl propertyStringImpl = (PropertyStringImpl) propertyObject;
What I can not figure out is how to set that value that I retrieve.
I need something line this:
bomLine.setPropertyObject("FOO", "new value");
- or -
propertyStringImpl.setValue("FOO", "new value");
Re: java: How to set a Property on a BOMLine in TeamCenter?
I never tried this, but may work. You may try SOA call DataManagementService.SetProperties() for BOMLine type of ModelObject.
Another not so direct way is to use SOA call CreateOrUpdateRelativeStructure.
I have used C#, there should be similar calls in Java.
