Do you mean
Reply
plm
Hi friends ,
I am a mechanical engineer with 1 year experience in mechanical design field . Now i am going to learn PLM Teamcenter . and i heard that it requires knowledge of prog langauges C and JAVA. I dont know much about these prog languages, so is it going to diificult for me.
And which prog language is most used in plm teamcenter?
what about the job opportunities ?
waiting for an expert advice..
 thank you.
Re: plm
It depends on your role for Teamcenter.   If you are going to be a Teamcenter Adminstrator only then there is no requirement to learn any language.  You only need to know programming if you plan on doing any programming.
Larry Carpenter, P.E.
Re: plm
Thank you very much for your response and spending your precious time .
I heard that , now days teamcenter customisation is having very wide scope and more oppurtinuties and it requires knowledge of JAVA.
what is your opinion .
Re: plm
Yes knowledge of Java is required for customising teamcenter. You can program your way through once you have a good understanding of how scenarios can be achieved in teamcenter manually.
I would also recommend knowledge of c++ as well.
Best Regards
Harish
Re: plm
Different areas in Teamcenter with prog. language requirements could be summarized as:
1. Tc Admin: No language
2. Server side customization: ITK (C/C++)
3. Rich Client, being eclipse based, requires Java knowlege
4. SOA API (CPP, JAVA, .NET) : required to develop Tc integration with third party softwares
