"Import Assembly into Teamcenter" now different in NX 11 ?
Hello
"Import Assembly into Teamcenter" style now different in NX 11 ? ( Photo left ).
  • Is there a "theme" or so to change it to similar like in NX 9 ( Photo right ).
  • "Export assemby's" style has remained the same ( Photo right).
Re: "Import Assembly into Teamcenter" now different in NX 11 ?
Hi @12131444,
This dialog is enhanced in NX 10. You can refer to the NX 10 what's new documentation link, Import assembly into Teamcenter.
I think there is no option to have that previous dialog interface.
You can declare the actions for a whole assembly now instead of piece by piece. You can Save-As to a new number, Revise to a new revision or None for no action. The enhancement is VERY useful and saves time.
Evaluating: AW 3.4
Hello ( *Photo* I had this step by step guide to the old NX 9 assembly import. )
Where is the 4th and 6th part now in the new NX 11 import ?
  • Import Numbering ? (Auto generate.)
  • Exceptions ?
4. Auto Generate => Numbering Source, Select 'Part ID Generator'
6. Exceptions => Once you select parts to import, there will be column 'Existing Part Action' below 'Names and Attributes for Parts to Import'
  1. How to select "user number", "auto generate", "auto translate" ?
    ( I see only= Default, Overwrite, Use existing, New revision.)
  2. How to sort the list for "Name only's" ?
  3. Some parts of the assembly need to "Auto Generate"=new number/name some parts need to "User Number"=same as the name in file.
Any guide for NX 11 import ?
I have an assembly: In NX 9 I do the import like this...
1. Some parts are bolts,nuts,washers (=standard parts found already inside TC ) which name should remain the same...*User Number*
2. Main parts should have the same file names as in Native NX *User Number*/*Auto translate*
3. "Name Only"-files => should be just *Auto Generate*
  • Lots of red in NX 11: "Working revisions limit exceeded for Item." "Item id is invalid".
Any idea what means the Error= "Working revisions limit exceeded for Item." ?
+ Why NX import finds "name only"-parts and such items that are not present in the assembly 3D-file ?
For those items with this warning/error, is there any working revision already present in the Teamcenter?
