search query for file extension
Hi, is it possible to search for datasets according to their extension (let's say only dwg or pdf files)?
Thank you
Re: search query for file extension
The query Dataset... allows you to search by dataset type, so PDF vs AutoCAD. Does this not work for your situation?
Jamie
Yes thank you, it was only easier than I expected :smileyvery-happy:
And is it possible to limit the query so to search only inside a specific Folder?
Not with any OOTB query that I know of.
You can select expand the contents of the folder, select all, show in details tab and filter by dataset type.
thank you
