what is pdo file
Hi all:
I want to know the basic idea about pdo file. What is it? What is for? How to create it?
If there is introduce document from siemens, Could post the link?
Thanks.
4 REPLIES 4
Re: what is pdo file
According to Google, .pdo is the Pepakura Designer software which creates 3D origami models that users design and then turns those 3D models into the 2D paper cutout files that are needed to create the actual origami project.
Evaluating: AW 3.4
Thanks Randy!
I also google the reult, but it is doubtful to me. I have a example of pdo file in hand. It looks like a template for assembly's PMI. That is very useful for our bussiness user.
I want to know how to create it.
The PDO example from Pepakura Designer web site is binary and clearly states the name when opened with Notepad++ so it's probably not the same. I'm not finding any other candidates for .pdo.
Evaluating: AW 3.4
It is a process document file. Frim vismockup file open you can see the option.
