wizard item create
Hi everyone,
I want to change the wizard to create an item and add properties you customized..
helpme please
Re: wizard item create
Joss,
You can customize the Item Creation and Item Revise Wizard by adding the custom properties.
in our TC installation, we have added the custom properties to an custom item revision, but we would need those properties to be filled by the user during the item creation, So, we have added these custom properties as a "Compound Properties" to the Item Revision Master Form.
Hope this helps !
PS: I think if you would need to move this to administrator's forum.
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
