Achieve a Smoother Finish When Finishing Steep and Non-steep Overlaps
Cut region overlap in Area Milling
Overview
You can now overlap steep and non-steep cut areas in Area Milling operations, allowing you to achieve a smoother finish where the areas converge.
Created with NX CAM 9.0.3
Details
The new Overlap Regions option allows you to specify a total overlap distance.
To use this self-demo, save the attached part file locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
