Automatically Smooth Out Cut Level Transitions and Engages
Create smooth non-cutting motions in Zlevel operations
Overview
This enhancement allows you to easily create safe, smooth, efficient transitions between cut levels in Zlevel operations.
Created with NX CAM 9.0.3
Details
These new Smoothing options override many of the parameters that would otherwise need to be specified separately for Engage, Retract, and Transfer/Rapid moves. In most cases, the default smoothing values will give the desired results.
To use this self-demo, save the attached part files locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
