CSE Simulation Customization for multi-function machines in NX CAM Software
Community Manager
This video training series was created by Thomas Feind, Machine Tool Enablement, Manufacturing Engineering Software, Siemens Industry Software.  If you have a question or comment, please use the COMMENT section below this post.
Overview
The following video training series explores the details of CSE customization in NX CAM Simulation for complex machine tools like mill-turn/multi channel machine.
Prerequisite
An advanced knowledge and understanding of NX CAM, NC Code, and CSE customization.
If you are a beginner with the ISV and CSE, it is recommended to start with the introductory training videos found here:  Understanding Machine Tool Simulation Concepts
NOTE: It will take almost a minute before all of the content on this page is displayed and you can scroll down. Please be patient while the previews for all videos are loaded.
The video training sereis was created with NX 12.0 for manufacturing
Contents
This video series is broken down into 2 sections (Basic and Advanced), as described below. It is helpful to go through them in order at first.  Having several chapters will m ake it easier to return to the material for reinforcement.
Learning Objectives
  1. Become familiar with advanced CSE customization for complex (e.g. multi channel/mill turn) machine tool functions
  2. Become a common understanding of controller behavior independent on a specific controller type
  3. Learn implementing complex functions by splitting them into smaller topics
Material Preparation
Save the attached sim_millturn_training_basic.7z file (found at the bottom of the article) locally and follow the instructions in the Basic Session 02. Setup Preparation
The used CAM setup “millturn_training_part.prt” and sample NC Code files CH1.prg, CH2.prg, CH3.prg are located under sim_millturn_training\sample\
If you want to concentrate on the videos without coding, there is a fully configured kit (sim_millturn_training_tobe.7z) with all shown modifications inside.
Table of Contents
Basics (53:46)
01 – Kinematic Model Setup (11:41)
02 – CAM Setup (06:31)
03 – Tool Change (10:44)
04 – Offsets (23:05)
05 – Useful Sources and Information (01:42)
Advanced (03:02:59)
Overview (1:25)
10 - B-Axis Head Offset + Tool Correction (31:05)
11 – Head Change (4:54)
12 – Head Correction (35:14)
13 – 5 Axis Simultaneous Motions (09:45)
14 – Polar Coordinate Interpolation (12:59)
15 – Cylindrical Coordinate Interpolation (08:50)
16 – Diameter Mode (05:40)
17 – Constant Cutting (11:45)
18 – Geo and Channel Axes Exchange (14:36)
19 – Spindles and Speeds (14:47)
20 – Syncronize motions on a multi channel machine (08:55)
21 – Using Devices – Steady Rest (08:25)
22 – Transfer Parts (04:33)
23 – Probing (04:33)
Introduction and Overview (05:40)
(view in My Videos)
Basics (53:46)
(view in My Videos)
(view in My Videos)
(view in My Videos)
(view in My Videos)
(view in My Videos)
Advanced (03:02:59)
Overview (1:25)
(view in My Videos)
00:00:00 – Introduction
00:03:01 – Setup and activate a kinematic chain
00:07:43 – Compensate b axis pivot point to tool mount position
00:13:31 – Compensate tool length due to rotated b axis head
00:18:40 – Rotating coordinate system
00:26:52 – Compensate 0 position in pivot point
(view in My Videos)
(view in My Videos)
00:04:40 – Calculate head correction in initial positon
00:11:44 – Setup and use combined chains (machine + head)
00:15:28 – Calculate head correction in rotated position
(view in My Videos)
00:00:00 – Direct angles
00:06:27 – Vector input
(view in My Videos)
00:01:16 – Machine2Piece and Piece2Machine definition
(view in My Videos)
00:01:02 – Machine2Piece and Piece2Machine definition
(view in My Videos)
(view in My Videos)
00:01:28 – Using HandleTEvent
(view in My Videos)
00:02:59 – Attaching a joint to the current channel
00:04:24 – Detaching a joint from the current channel
00:09:33 – Changing Geo Axis
(view in My Videos)
00:00:55 – Set a main spindle
00:02:19 – Set spindle speed an spindle mode
00:05:55 – Position a spindle
(view in My Videos)
(view in My Videos)
00:00:31 – Install a device
00:02:13 – Simulating part clamp with steady rest
00:05:11 – Calculate touching value and moving axes in AC Language
(view in My Videos)
00:00:35 – Clamp a part with a chuck
00:03:08 – Transfer part from chuck to device
00:03:56 – Transfer and clamp part from device to chuck
(view in My Videos)
00:03:45 – Activate measuring in motion
00:05:40 – Storing measure points
00:08:06 – Reusing measured points to set local offset
(view in My Videos)
Content
Comments
I don't see the "SteadyRest" folder included in the zip files.
Steady Rest is now included. Sorry!
Are the training slides shown in the videos available for download? If so, where can they be found? If they currently are not available, could they be made available?
Thank you
 slides are now available for download in the content section of this post.
Thomas
Thank you Thomas!
Dreamer
Dreamer
These videoes are exactly what i want, but instead of the slides, I have some problems with accessing to the videos.  Smiley Sad   It'll be great help if I can download the videoes.
Thx
Theorist
Theorist
I can't find Machine Configurator in NX10. Can anyone help me? Thank a lot
please add your question to the discussion forum.
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/bd-p/open_forum
FYI: In NX 10 you´ll find the Machine Configurator within the Simulation Control Panel
Thomas
Theorist
Theorist
Thank you very much, Thomas
Hi Thomas
Thank you very much for this videos. I have to implement a very common device handling (I found only video 21 for devices): 4th axis on a machine. Like the sim04_mill4ax. it was easy to attach the joint to the channel so that the 4th axis was recogniced. But this Machine with tnc620 controller has PLANE AXIAL and TCP mode. I tryed to add a head object and use the mounthead functionality, to get the kinchain. (AC). But I was not able to mount the device to the table. It was possible to "S" but, you can imaging, that was not what I want. Do you have also a video which describes this situation?
Thanks very much for an answer.
