Completely Machine Both Sides of a Blade Without Edge Rolling
Completely machine both sides of a blade without edge rolling
Overview
In Multi Blade operations, the Blade Edge option controls where the tool path stops following the blade geometry and begins extensions. You can now use the new No Curling option to prevent the cutter from rolling over the blade edges.
Created with NX CAM 9.0.3
Details
No Curling extends the tool path tangentially without rolling around the sharp corners.You can also enter an Extension value to further extend the path tangentially.
To use this self-demo, save the attached part files locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
