Controlling the depth of the chamfer tool by offsetting the drive point
Control Chamfer Tool Depth
Overview
You can now control the depth of the chamfer tool by offsetting the specified drive point above or below the specified chamfer reference.
Created with NX CAM 11.0.0
Details
Chamfer Reference indicates which diameter of the chamfer (minimum or maximum) will be used to reference the offset distance. Depth Offset indicates the distance between the Drive Point and the Chamfer Reference. A positive value offsets the drive point below the referenced chamfer. A negative value offsets the drive point above the referenced chamfer.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
Can you provide the .prt file in a .zip format please?
Theorist
Theorist
That is great info many thanks! It worked perfectly in NX11 but how to do the same thing in NX12?
many thanks,
MechJohn
Which NX 12 release? NX 12.0.2 MP4 definitely has it.
Contributors
LIVE Tech Tip Webinars
Watch NX experts demonstrate manufacturing best practices. Stay online for Q&A.
