Create a mill-turn postprocessor
Siemens Genius Siemens Genius
Siemens Genius
Overview
This is video 12 of 16 in a series about how to create and edit postprocessors with NX Post Builder.
(view in My Videos)
Tech Tip by Jim Wright, Siemens PLM Software
Details
The NX Post Builder application is extremely flexible and powerful, and can provide useful benefits. This online Tech Tip series is intended as an overview of the post builder and postprocessing workflows in NX CAM.
Much of the content discussed in these videos is fairly advanced and while potentially valuable to everyone, it may be more useful to those of you with post processor experience. To get the most from this series, we suggest that you watch the videos in sequence. You can find the other videos in the Postprocessor section of this Tech Tip Knowledge Base.
Videos in this series:
  1. What is a postprocessor?
  2. Create and test a 3-axis postprocessor
  3. Modifying tool change and work offset output
  4. Changing G-codes in Post Builder
  5. Tool Command Language (TCL) - Part 1
  6. Tool Command Language (TCL) - Part 2
  7. Tool Command Language (TCL) - Part 3
  8. Tool Command Language (TCL) - Part 4: More on IF statement
  9. Tool Command Language (TCL) - Part 5: Source and Switch
  10. Using the Custom Command Library
  11. Create a lathe postprocessor
  12. Create a mill-turn postprocessor
  13. Create a 4-axis postprocessor
  14. Create a 5-axis postprocessor
  15. Tilted work plane
  16. User Defined Events
Do you have a question?
Click 'Add a Comment' below to ask it. (You must be signed in to use this feature.)
Make Better Parts Faster!
Aaron Frankel (Community Manager)
Comments
Dreamer
Dreamer
Can anyone out there help me the post for Multi-axis B750 Okuma or where to start with? I have sub spindle and steady rest as well, thanks
VIP
VIP
For general questions, I suggest you ask in the Manufacturing Discussion Forum - there are many experts there.
Hello.
Thank You for beautiful Lectures and constant support to CNC Community.
I try to create Mill-Turn Post, but in order to do so, I need transfer some of the Variables from "Program Start Sequence"
in Lathe Post, to "Program Start Sequence" in Mill Post how I can efficiently do this?
